UPDATED ABRIDGED VERSION FROM PREVIOUS POST. PLEASE HELP!!!
2000, HPDI, 200HP, 535 Hours. Just completed a rebuild, compression 120. ALL fuel filters are new. High pressure pump was sent out last year for service. Injectors too.
Symptoms: rough idle, slow throttle response, misfire/backfire, puff of blue smoke emits from exhaust in sync with misfire. White smoke when I rev it up. Found the upper LPFP was leaking. Replaced it. Still have white smoke. I did not have these symptoms prior to the rebuild. Engine is being run in a test tank in gear using the harness, oil tank, ignition switch & gauges.
Confirmed running spark on all 6 cylinders. When injector connectors or spark plug boots are pulled on cylinders 1,2 & 3, there is no change in the poor running condition. When 4,5 & 6 are pulled the engine stalls. Timing shows 4 btdc in neutral and TDC in gear at idle on YDS. No codes
Spark plug boots, coils, pulser coil, o2 sensor, injectors, tps (set to 61) all ohm to spec. Shift position checked out. Swapped injector 2 with 5. Same running results I unplug injectors or boots on 1,2 or 3. No corrosion on any connection or grounds.
Swapped out the injector driver and then the ecm. No Change! Pulled the STBD fuel rail with the injectors attached, cranked the motor and all the injectors had a great atomized spray pattern. Didn't pull the port side. Assumed #2 was spraying too. Checked flywheel, still in its keyed position. I have fuel compression and spark. What else can I check???
