I paid about $8 apiece last time I changed mine. I believe you can download an owners manual from Yamaha that will give you the info on service intervals and basic part numbers.
Mr. CIA Guy:
From what I can tell, the chrome kit only includes the "outer plate, cartridge" and the "insert, cartridge", nothing else. I never ordered a "chrome kit". I do know that in the standard complete kit I order (w/housing) both the plate and insert are made of non-ferrous metal (magnet will not pick them up). I am assuming they are made of stainless steel. Never had anywhere near excessively worn or corroded plate or insert. So why would anyone use the "chrome kit"?
Has any member ever used a chrome kit?
If anyone is boating in the type of environment where a regular water pump is failing sooner than the boat would like, due to wear and tear, then they may want to consider the use of the chrome kit. Chrome is very hard. Stainless by comparison is soft.
Yeesh, $8 a piece. I;m glad there's only 4
Believe it or not I actually have the original owners manual with the boat. I saw the maintenance intervals in there but I don't remember seeing anything recommended for plugs, just lubes.
OK, I guess there is an application where someone would use the chrome kit. From what I've read, boating in waterways where there is an excess of silt is the main reason for the chrome kit. Silt acts like a fine emery cloth on the plate and insert. Maybe the Mississippi River?
I wonder what silt does to a rubber impeller?
I can say the impeller on the F150 is EXTREMELY STOUT.
It will take a set of course, but an old one I pulled out, for S&G's, I tried cutting a vane off...
Holy crap, I don't think one would ever come apart. I worked with a
new razor blade trying to cut a vane off. Of course I succeeded, but it was NOT easy.
For the OP, check your PM's...
O.k, my water pump should be delivered today so I can put that in. Is that something I can do myself or should I try to get some help with the lower unit?
Now I just need to get my thermostat and put it in. Should I try to flush out the water cavities to remove the rust before installing the new thermostat?
Also I still haven't been able to get that hose nipple out and I don't have the ability to sweat the copper and the piece in the hose looks split.
Does anyone know of a good site to help me repair my *****ing motor?
we have no idea what you are capable of doing yourself, but most replace water pump kits themselves.
always a good idea to flush out loose stuff from the passages when you can
maybe you need to have a shop look at dealing with that nipple,
or buy the cover if it comes with it installed.
we have no idea what is wrong with your *****ing motor, and I have not heard of a shop that does repair on them if it was not the service center for that brand of motor
