K, fresh plug grounded to block shows thick bluish white spark.
Reexamine the bowl and it looks seated perfectly from just looking at it. Squeezing the bulb doesn't show a leak anywhere.
To be honest I had the motor tilted up earlier so I don't know if maybe it came from the throat or the bowl.
If there's anymore things I Caan check without taking off the carbs I'm all ears, otherwise we will have to wait till Friday to continue when I rerereexamine carb 2 =/
Thanks for all the help and suggestions so far. Really is a great crew on here
Btw before I put carb 2 back on I tested it upside down blowing into it and it didn't allow anything, but I didn't know about vaccuum testing. Is that done upside down to so the needle is seated?
