Hi Can anybody help. The charging coil (the one that supplies the power to the CDI) has blown. As it is an old motor, it probably is easier to wind the coil myself. Any idea of what the resistance should be?
Charging coil resistance?. 1980 Yamaha 40 BM
Originally posted by boscoe99 View Post205 ohms brown lead to blue lead. Plus or minus 20%. At 68 degrees F.
Don't forget to check either of the leads to ground. There should be no connection to ground.
Now, questions come to me. I am assuming elliotgr is going to measure the circumference of the coil wire (gauge), find out the ohms per thousand feet of new wire, and calculate the length of the coil wire he needs for the resistance you posted?
Does amount of turns need to be considered?Chuck,
I think that the diameter of the wire would be measured to determine the needed wire size.
The number of turns should not affect the resistance as long as the total length and diameter of the wire remains the same. But...
Voltage generated when a magnet passes a coil is a function of the number of turns of the wire in the coil. More coils means a higher voltage. Amongst a number of other things of course.
So, the same number of coils should be used if and when the charge coil is rewound using the same gauge wire as was used in the original coil.
I appreciate folks that take the time to do something like this.
Originally posted by boscoe99 View PostI think that the diameter of the wire would be measured to determine the needed wire size.
So, elliotgr would need about 190' of this 40ga magnet wire to get 205 ohms resistance. Say (again, for discussion) his iron core is equal 2.5" in circumference and after the coil wraps the coiled wire winding is about 4.5" circumference. Average would be 3.5".
Number of turns should equal about (190' x 12)/3.5".
That would come to about 650 turns.
Do you think just being sure you wind the proper gauge magnet wire of the resistance length needed on the core tight and even would be accurate enough? I'd probably make a rig to use on my drill press to do this?
What ya think elliotgr/Boscoe?Chuck,
Thanks for all the responses. The charging coil was 120 to 150 ohms according to an old manual I found. The two old coils I had both measured 135 ohms but gave different issues. One would not idle, the other would not let the motor go past 3/4 throttle. Must have been breaking down under load. But I did it the easy way. Measured thickness of wire. Got resistance per meter for the wire which was 0.18 mm thick and 0.679 ohms per meter. Meters required = 206 m. So wound on 206 m by eye based on previous thickness of coil and then slightly over-wound it. I made a simple jig on the lathe and ran at slow speed. Took about 5 minutes to wind. I then stripped back small part of varnish on wire to test. Result 139.9 ohms. So sealed it with epoxy and back into motor. Motor starts and revs. Now to test under load on the weekend. Will let you guys know how it went.
Originally posted by elliotgr View PostThanks for all the responses. The charging coil was 120 to 150 ohms according to an old manual I found. The two old coils I had both measured 135 ohms but gave different issues. One would not idle, the other would not let the motor go past 3/4 throttle. Must have been breaking down under load. But I did it the easy way. Measured thickness of wire. Got resistance per meter for the wire which was 0.18 mm thick and 0.679 ohms per meter. Meters required = 206 m. So wound on 206 m by eye based on previous thickness of coil and then slightly over-wound it. I made a simple jig on the lathe and ran at slow speed. Took about 5 minutes to wind. I then stripped back small part of varnish on wire to test. Result 139.9 ohms. So sealed it with epoxy and back into motor. Motor starts and revs. Now to test under load on the weekend. Will let you guys know how it went.Chuck,
Also if the old ones were breaking down the volt meter would have shown that by monitoring the voltage while the problem showed up.
very strange one would break down at idle and the other at higher RPMs
ÂÂ
