hi, I have a 2016 20hp 4stroke that seems to starve for fuel after running wide open after a few minutes, if I quickly pump the bulb it will keep going, if not it stalls. any ideas, my local shop is closed for the season. thanks
2016 20hp 4stroke starving for fuel?
stating the obvious: if pumping the bulb cures the symptom,
then
- the fuel pump is not working properly
- or there is an air leak between the pump and the bulb
- or there is a restriction between the tank and pump which the additional "help" of the primer overcomes
odd little fuel pump btw.
what does the extra "cylinder" with the brass hose barbs do?
Looks like it plumbs into a water jacket "outer exhaust plate":
Hose routing:
http://www.boats.net/parts/search/Ya...UEL/parts.html
Outer exhaust plate (part #8) where hoses go to:
2006 and Later F20SMHA_01 Yamaha Outboard CYLINDER CRANKCASE 1 Diagram and Parts
You have to look at both parts fisches to follow the hose barb/hoses which lead down to the mentioned plate that has an anode in it...
.Last edited by TownsendsFJR1300; 12-02-2016, 08:58 PM.Scott
Originally posted by boscoe99 View PostFuel cooler. Fuel/water heat exchanger.
and perhaps another possible "failure mode" for the OP :
if the pump housing is not cooled as designed, due to insufficient water flow
could that result in "vapor lock" -
(fuel "boiling" on the suction side of the pump)
Originally posted by howie597 View Postthanks for the input, i'll check for air leaks/blockage before I take it in for warranty, I heard the earlier ones had a vapor lock problemChuck,
Â
