I have a '93 50hp 2 stroke. The propeller has a ding on one blade and there is a small oil leak behind the prop. I'm getting a mechanic to look at it - hope it's nothing major. Has anyone had a similar experience?
2 stroke 3 cylinder 50hp
Weird? Nah, just a boat owner. Bet every one of you has sniffed your exhaust!Last edited by pstephens46; 11-27-2016, 03:41 PM.
A prop shop can fix the prop. The mechanic's just going to send it out and get a "cut" of the job..
Might be worth your while to pull the prop (one NUT) and check for fishing line up under the prop...That could cause a leak.
Most likely the prop seals (two) leaking...Scott
You can recondition the prop at your local prop shop. Aluminum reconditioning is very inexpensive (I paid $35 when I had an AL prop), SS a little more expensive than AL. Whichever material prop you have, your prop looks brand new after reconditioning.Jason
