thanks for the description on the pressure relief valve , which is on the port side next to the oil filter > So when cleaning the oil pump , I will need to pull apart and replace the gasket and 3 seals in the middle of the upper and lower pump housing , correct ?
150 flywheel magnet threads for puller
Originally posted by gsdanno1 View Postthanks for the description on the pressure relief valve , which is on the port side next to the oil filter > So when cleaning the oil pump , I will need to pull apart and replace the seal in the middle of the upper and Ignore lower pump housing , correct ?
Originally posted by pstephens46 View PostI had my YDS hooked up to my F150. Oil pressure was 65.5 at idle.
I assume the strainer can be cleaned without disassembling oil pump? I remember Rodbolt warning how easy the screwheads strip on the pump. Not to be confused with the mounting bolts....
I'd have to look at the shop manual, parts fisch to get a general idea...
For the OP, one good thing, it's NOT knocking yet so perhaps you lucked
out and didn't toast any bearings. Time will tell....(inspection inside too)...Last edited by TownsendsFJR1300; 11-30-2016, 05:17 PM.Scott
getting ready to order necessary parts and pull the power head , oil pan , etc. going to have to make some $$ first though ! I've rebuilt several auto engines and automatic transmissions , so mechanically I'm not too worried about the process , it's just a bit different from what I'm used to . Never had a harmonic balancer take 2 days to remove !!!
