F90 ECM question
  • F90 ECM question
    I'm very familiar with the simple epoxy-potted plastic case of my F225 ECM-
    so I was taken aback yesterday at seeing the ECM of a 2006 F90
    > what is the purpose of that "button-like gizmo"?
    the only thing I can imagine is that there is "air space" within the case
    and that is a "vent"...
    IDK?
    Manufacturing process? Is the plate you refer to molded plastic or epoxy? If molded plastic, maybe that is how the inject the epoxy?
    Chuck,
      Looks like a gasket there too.
        Maybe it releases the cover? You shoulda pressed it!
          LOL I did try touching it - no feeling that it moved.
          Definitely looked like a silicone o-ring down in there.
          But I wasn't curious enough to unplug and remove the whole thing
          By the way, this is what the back of the F225 ECM looks like:
          which actually brings up another mystery:
          why did they sprinkle kitty litter in with the potting epoxy?
            Potting and Encapsulation Applications | MasterBond.com
            Different "fillers" are used for various reasons.
            Effect of Fillers on Epoxy Properties
            Exotic fillers play an essential role in the formulation of adhesive, sealant and coating compounds. They enhance a variety of important properties including machinability, corrosion resistance, flame retardancy, thermal stability and abrasion resistance. Specific fillers also provide electrical conductivity, superior heat dissipation characteristics. They also can be used to control viscosity, reduce shrinkage, lower weight and improve dimensional stability.
            Effect of Fillers on Epoxy Properties | MasterBond.com
            Chuck,
              not only that, but they need less epoxy if they put fillers in and do not change the properties of it if the filler does not mix to dilute the original
                Not really a de-rail, but related...
                My old transducer has a similar (looks the same actually) material to seal water out.
                Overtime, it has begun to leak. IE, it appears to melt and then leakage out the back of the unit.
                I tried epoxying it, no go... I did find a new oem transducer (their not made anymore) and this one IS still working (for now).
                If I could "re-seal" my current one and get a couple more years put of it would be great.
                It does appear that the sun cooked it and that's what liquefied the inerds.
                It does NOT see the sun with the canopy over the boat(on the lift).
                Anyone ever "re-seal" this (it'd be the same as doing an ECU)??
                  Sounds like my ex-wife! Time to upgrade!
                  Chuck,
                    And WHO caused the "leakage" Chuck????
                      I won't go there!!!
                      Chuck,
                        I won't go there!!!
                        Apparently you already were!!!!
                        Ah, maybe the mailman..
                          careful, you could take a vacation like boscoe if someone does not like what you write
                            Hoping maybe it was the direct affront. Like Solo does. But then apparently someone has to complain too. No free for all here. I think we are within bounds and can call out as needed? Hate to lose the humor that this forum has had.
                              He wasn't banned for anything. There's been MUCH worse here...
