Gear oil plug
  • Gear oil plug
    Stupid question drain plug the longer plug goes on top or bottom?
    doesn't one (possibly the "longer") have a magnet in it?
    that goes on the bottom
      Can't remember. But the bottom plug usually has a small round magnet on the tip to attract metal particles. At least mine does.....
        One has the long tip the other is flat
          See which one may be magnetic. I would take a pic of mine but can't get to boat right now.
            "drain" means bottom: link w/ photo of "long" plug
            688-45341-10-00 YAMAHA PLUG, DRAIN
            the other is the "top"
            90340-08002-00 YAMAHA PLUG, STRAIGHT SCREW
              long one on the bottom.
              on some models if you put it on the top it wipes out the thrust bearing.
              seen it done.
