'98S115TLRW; 704 Remote Control
On the water today the remote control tilt/trim UP switch would intermittently not respond. When it would not respond at the control, the engine mounted UP switch did continue to work. This intermittent UP switch loss lasted maybe 10-15 seconds. I'd toggle the UP switch on/off until it functioned. No problems with DOWN switch.
I can only assume this is the beginning stages of switch failure? If you have a good wire diagram please post (Boscoe!!).
Recommendations on where to start the diagnostics? My dad recently had an issue with his 704 switch. Turned out it wasn't the wiring, but I think one of the contacts in the switch?
I guess it's time to pull out the multimeter again. Hell, it's only been 2 weeks since locating the bad wire in my oil harness. Woohoo, electronics are soo fun.
Thanks guys.
Thanks guys.
