The steering friction adjusting lever doesn't work on my outboard, how do I check the operation and adjust it ?
F25AEHT Steering
Looks to be about a 2002 model year motor. The equivalent I believe of a USA F25ELHA/F25MLHA model. One is electric start with a tiller handle and the other is a manual start with a tiller handle. If your motor is not either of these then let us know.
Underneath the friction plate you should find some hardware that can be adjusted so that the steering lock lever will be more effective. Maybe loosen the lock nut, tighten the steering lock shaft and then re-tighten the lock nut.
See this illustration
2002 F25MLHA Yamaha Outboard STEERING FRICTION Diagram and Parts
You are welcome.Last edited by boscoe99; 11-24-2016, 05:31 PM.
