yamaha maintainance tools
  • yamaha maintainance tools
    hi, we got some Yamaha tools to check compression , fuel line and etc... some of our engines reaching its 1,000hrs. it shows on manual how to use it . but it looks like part of this tools are missing. I need support to get on track .
    not enough information for anyone to help you
      this is what I got for fuel pressure test. kindly advice me rest of the parts need to complete...
        looks like the gauge should just attach to the tee that you hook to the fuel line after the pump.
        nothing for compression testing
          the one on the left looks like some kind of gauge and the fitting for attaching a fuel pressure guage to the rail.
          the one on the right looks like a mity-vac pressure vacuum tester.\
          I cannot open the thumbnails.
            In your original post you mention a compression check. Suggest you get a direct compression gauge and a differential pressure (aka leak down) check gauge.
            https://www.google.com/webhp?sourcei...gauge&tbm=shop
            https://www.google.com/webhp?sourcei...eakdown+tester
            And once we know what your specific model is we can look in the service manual to see what additional service tools are recommended.
              Yes, but the scale on what is pictured says MPa. 1 Mpa is equal to about 145 psi. If this is correct, the top end of the scale of 16 would be psi of 2,320 (highly unlikely). I think a cheap gauge with incorrect markings is more likely. If the scale is supposed to be in psi, your top end of the scale would not be sufficient for your fuel rail pressures. You probably need a gauge with top end of scale in psi from 60 to about 100 psi.
              Chuck,
                the gauge on the left actually looks like the one used for testing power trim pressures.
                but I cannot open the picture.
                  Where do you attach to trim unit?
                    depends on the unit being serviced.
                    not ALL Yamaha trim and tilts are the same since 1984 here in the US.
                      Ok F150TXRD 2005? There seems to be a plug at the bottom of trim unit?
                            that gauge can also be used to test certain up and down main check valves.
                            it CANNOT be used to test engine compression.
