I have replaced a few, the one for the v8 is about 2800.
typically a 3.80 dollar bushing is the failure.
typically the corrosion builds between the bushing and the bushing housing just under the powerhead.
bind it up to bad and keep trying to make it shift and it burns out the motor windings.
no way to lube it and the powerhead has to be removed to access it.
did a set of triple f350 motors a couple weeks ago.
one actuator burned out and the other two binding.
