Shift linkage/gear grind
  • Shift linkage/gear grind
    I've got a Yamaha 25hp outboard that I just replaced the water pump in. When I started it to check things out it had a tick/grind in the gears. An Internet search got me here and pointed me in the right direction. The foot wasn't completely in reverse when I dropped it, apparently. A push on the rod and a turn of the prop got it right. Sometimes a little guidance is all someone needs. Especially a stubborn person that thinks it was right in the first place(me).
    I'll bookmark this site for sure. Thanks.
    Fixed, broke, and fixed in the same post!
    Stick around!
      just remember.
      that barrel nut is NOT an adjustment.
      it is simply a shift rod connector.
        Stick around!
        His post could be the best I've ever read lol.
        No doubt the drive shaft-shift shaft linkage is a pain on those smaller engines. If yall can remember, I became a member on this forum bc I was experiencing the same issue with my then engine, '98 25hp. First time I replaced the water pump on that engine I couldn't engage reverse. It boggled me for hours.
        Jason
