Just what the title says ... I need both for my 05 F90
Aftermarket Trim/Tilt motors and relays ?
Originally posted by pstephens46 View PostDid you physically put the motor leads/wires on a good battery to test? And then swap the leads between plus and minus to reverse motor?Key West 1720cc
Yamaha F90TLRD mfg.05/04
did you see this post and pic on brushes?
maybe you need to open your up and have a look to see if cleaning things up would work instead of buying a new motor.
http://www.yamahaoutboardparts.com/f...d-th27545.html
Also it sound like it is working well after you put it back together, maybe you had a bad connectionLast edited by 99yam40; 10-23-2016, 10:44 AM.
Mercury Marine makes a retrofit kit to convert from the expensive Yamaha relay assembly to two standard Bosch relays. About ten bucks a relay. Replace only one or the other if and when one fails.
See Sierra for a non-Yamaha tilt motor if needed.
Originally posted by boscoe99 View PostMercury Marine makes a retrofit kit to convert from the expensive Yamaha relay assembly to two standard Bosch relays. About ten bucks a relay. Replace only one or the other if and when one fails.
https://www.amazon.com/Reversing-Con...or%2C+WindlassChuck,
