Just changed the fuel filter on 2005 F150TXRD. Tried pumping the primer to fill the filter assembly with gas. Could not see any gas flowing into it. Can I start the engine to prime it? I am concerned I may get air into places that may not need it.
Engine mounted fuel filter F150
The system is self bleeding.
Start the motor. It will run for quite a while on the gasoline that is in the VST. When the motor is running the mechanical fuel pump will be operating and drawing fuel from the tank and sending it on through the filter to the VST.
Regarding this engine mount fuel filter - when running, the fuel level is right at the bottom edge of the filter element. I would think it would at least be as high as the top of the yellow filter. Who knows? I never paid attention prior to changing. Ran it quite a bit, to make sure no leaks beneath the cowling and it didn't miss a beat.
