2008 Yamaha 25hp 2 stroke
I changed the shift rod lever because it was munged up. That required me to remove the powerhead to reach it. So I did that and put everything back together with the new shift rod lever installed.
Now when I put it in reverse, the lower shift arm doesn't go far enough down to push the clutch dog into place. Seems that somehow I've shorted myself a half an inch out of the shift rods lowering capabilites. Where could I have gone wrong in putting everything back together? Everything looks ok, and there doesn't seem to be any out of place parts that could restrict the movement of the shift arm or shift arm lever?
This is as far as the shift arm goes down when in reverse.
[IMG][/IMG]
[IMG][/IMG]
