New Tachometer Issues
  • New Tachometer Issues
    Hi All,
    I'm hoping that someone out there can help me with a problem I've got. I've recently changed the tach on my Yamaha 60FETOL. The old tach was a 6Y5-2818R -30 and the new one is a 6Y5-8350T-83-00. I have changed the tilt/trim wiring to the 2 wire set up and have installed the adapter cable.
    My problems are:
    1. The tach indicates only half the RPM that the engine is running at.
    2. With everything connected and the oil tank full I have a flashing oil light and a permanent alarm.
    However, when the oil tank is only a third full I get no flashing indicator and no alarm. I have purchased a new oil level indicator and it has made no difference.
    I have tried the DIP switches in every combination and nothing changes regarding the alarms
    Any ideas?
    Which end of the trim/oil harness is the adapter cable connected to?
    Also, what is the complete ID for the motor?
