I decided to pass on buying new, so I found a used F150 with 500hrs.
A reputable marine shop has had the motor in a crate for the past year since the boat owner repowered.
Shop owner has the computer read-out and compression test results.
If bought and after mounting on the boat, changing the impeller, putting fresh motor oil, lower lube oil and new spark plugs, what else should be done prior to starting?
Any questions I should ask and anything in particular I should be looking at?
