I have a 2003 yamaha ox66 efi that has a problem of stalling at idle sometimes in gear and sometime just idling at the dock. It will start right back up after stalling. Its like it sneezes once big time and stalls.
I know that sneezing usually refers to lean condition but it seems that its running a little on the rich side to me .
I've had the injectors cleaned and checked
Ive checked the fuel pressure which is good at 32 psi
I've replaced the low pressure fuel pumps and even rechecked them for being good .
Ive replaced the tps and set the voltage to spec with a DVOM after finding and open in the sensor as it was ranging up.
base idle is set at 750 RPMs.
any help would be appreciated
