Over the last few seasons, my S150TXRW has developed power loss in the cruising range. Sounded like a cylinder or two was dropping out intermittently.
This season it got worse. I finally got around to rebuilding the carbs after alot of troubleshooting. Every single float (total of 6) were sitting way too hi, meaning there was not nearly enough fuel in the bowls. The needle valves have a rubber end which contacts the float. They had become swollen, I am assuming from ethonol in the gas. After correcting the hight of the floats the problem is gone.
Just thought I'd pass this along.
