Hello Guys Need some help.
Yamaha 225 HPDI run rough at idle. Last week I check signal on spark plugs with software all fire static test but I start motor on a tank check signal with induction gun light 4 cylinders work on neutral and the 6 on forward but after some minutes check signal on cylinder 5 on neutral not signal then intermittent on forward intermittent on cylinder 3.
I shut off and check again after 20 minutes signal in all the cylinders.
Any clue is apreciatted
