10 and 11 was in a poor condition and is not replaceable, have now removed them completely - according to the Yamaha service engineer - these are there to damper noise. I do not believe this can be the reason for the spitting water.
2001 Yamaha 90 hp 3cyl 2 stroke spitting water
Originally posted by Rlilleaas View Post10 and 11 was in a poor condition and is not replaceable, have now removed them completely - according to the Yamaha service engineer - these are there to damper noise. I do not believe this can be the reason for the spitting water.
By the way, you have a portable lift? I see the hydraulic unit in the pic. I have a BendPak Model# MD-6XP coming. Do you have this one, how do you like it, any quirks?
Chuck,
By looking at the drawing it seems like you are correct, its available - I choose not to order this part now, but worth a shot if the water keeps spitting out after assembly. A bit more exhaust sound doesnt hurt anyone.
I believe my garage lift is in one of the other pictures / another page. It has been included in the design of the garage floor and is thus flush
It is a "chinese" build, assume the unit you are reffering to is a US model. Great fun regardless.
Originally posted by Rlilleaas View PostBy looking at the drawing it seems like you are correct, its available - I choose not to order this part now, but worth a shot if the water keeps spitting out after assembly. A bit more exhaust sound doesnt hurt anyone.
best to keep all of the parts they were designed to have
So bottom line, what was the problem after all ?
I have a similar "problem" ( I don't know if that's a problem after all ) . My 25hp motor spits water through exhaust hole and it spills through one of two holes right above the lower unit on the boat/shift lever side. Is it normal ? ( see attach)
Note: the motor pictured is not mine, It's a similar one from youtube. I've just wanted to picture the issue.Attached Files
Hi,
Apologies for the late reply, bought myself a Mariner Optimax and a new boat and have not used the Yamaha that much (still have the Yamaha however,)
It must have been the cracked gasket below the power head, that caused the spitting water
mvh
Roar
