Hello Everyone! I have a 1998 S115TXRW Yamaha outboard that the overheating alarm is going off on. I use it mainly in saltwater and flush it after every use. When running at WOT after about 5 minutes the overheat alarm goes off and the engine rpms drop. After turning off the engine and waiting several minutes I ran the motor at around 1500 rpms back to the dock with no alarm going off. I took it to a local boat dealer for service. They tried getting it to overheat in the shop, but were unsuccessful in getting the alarm to go off. They replaced the water pump impeller and water tested it saying it was fixed. I took it back out and it did the same as before for me.
I flushed it with Rydlyme Marine per instructions as shown in this forum by others. I noticed some corrosion in the thermostat area and the thermostats looked pretty corroded. I replaced both Thermostats and gaskets, the pressure control valve, grommet, spring and gasket. Took it back out on the water and the same thing happened as before. Ran it a WOT and after about 5 minutes the alarm went off and rpms dropped. Started it back up and limped back to the dock under 2000 rpms with no alarm sounding.
I ran the motor in a 50 gallon tank at idle between 900 and 1100 rpms for about 30 minutes trying to get the alarm to go off, but it didn't. While running it I took temperatures with a infrared laser thermometer. I took a reading in front of the thermostat and behind. The starboard side read as high as 133 to 136 front and back while the port side read 129 to 133. At the thermo switches the starboard side read 142-146 and the port side read 135-138.
What could be causing the overheat alarm to go off? What should the temperature be at idle speeds between 900 to 1100? Do you think that there is blockage or partial blockage in the water jacket somewhere? I am trying to avoid taking it apart to check the water jackets if possible. I have read in this forum that on older motors the bolts are prone to breaking off. Any advice would be greatly appreciated.
