Hi all ,
I have a 1995 70 HP BETO 2 stroke.
The motor won't go pass 3000 RPM. Try to clean the carbs, fuel lines, tested the resistance from every part from iginition to sparks - everything as in manual.(another thread)
I noticed that maybe the fault was in fuel pipe joint on a motor side. I don't know why yamaha has a pipe joint with a moving pin.(or maybe it should't move). The movement should be in or out, but i noticed that it goes to left or right all the circle. ????
I have one old evinrude 9.9 and there is a fuel pipe joint pin that can only move in or out, not to the sides because is metal surrounded.
Has anyone tried to install a new type (6YL-24304-00-00 ) fuel pipe joint from newer yamahas.
I saw that the newer type pipe joint was changed to round plastic one. Are these connectors better in compare to older type joints used?
I'm also tried to find a matching male joint for (6YL-24304-00-00 ) on parts, but with no luck, only the male joints with hoses and primer bulb in package.
Could be installed to older yamahas like mine?
THX
THX
