Not sure if the part is oil seal housing or manifold extension. It is a casting where the shaft slides into the power head. The motor had been siezing when stored. When I went to remove lower unit I needed wedges, when done this part is shattered, what was left of it after corrosion anyway. This is used in salt water.
How hard is this to replace? Do I need to split the motor?
