I have a 2005 f40ejrd pump jet motor. I want to change my steering from tiller steer to steering wheel. What parts would I need to do so. Thank you.
Tiller steer to steering wheel
Your motor started life without a tiller handle so someone added it along the way. Probably along with a steering friction kit.
Remove the tiller handle and steering friction kit.
Install a new control box of your choice. Depending upon the control box you may need a key switch and kill switch. Connect the control box to the motor. Electrical harness and throttle/shift cables.
Add a steering system. Mechanical type typically.
