Took the boat out to go crabbing this morning and shortly after leaving the ramp the engine started running bad,maybe on 2 cylinders then cut off.I checked the fuel line and tank and just to make sure swapped tanks and line.Got it started and put it up on plane for about 5 minutes without incident.Started dropping crab traps and after a few it just cut off ...checked fuel lines and had gas going to carbs...still no start.Had to use my 4hp kicker to pick up traps and get back to the ramp.
One I was home I checked the spark and nothing initially ,then checked the pick ups and stator with an ohm meter and all were within specs...check the spark again and observed spark (bright sun did'nt help)...Tried to start and it ran on idle for about 5 minutes then it shut off and would not start again.
I'm thinking my power pak was going,going ...gone.Would this be a logical assumption? Had to replace one on a 9.9 Johnson that acted the same way.
