I have cleaned carbs ,replaced fuel pumps, checked and rechecked tps settings,link and sync per yamaha manual,checked pulsar coil and stator output with peak voltage adapter all within specs, swapped cdi and coils with port engine, compression between 105-110, it seems like a ignition miss checked the plug caps and wires all within specs,
The motor seems to run better at wot than at half throttle, it loses 2-300 rpms like a ignition miss, the last time I ran it at the river all 6 plugs looked wet, no visible leaks at fuel solenoids. Any help would be appreciated
