is it possible to put a water pressure gauge in Yamaha OX66 200HP motors
  • is it possible to put a water pressure gauge in Yamaha OX66 200HP motors
    I've got a pair of Yamaha OX66 200HP motors -- is it possible to put a water pressure gauge in these motors? If so how?
    Absolutely positively.
    There is a port in the top of the cylinder head into which a plug is screwed. Remove that plug and install a Yamaha water pressure fitting. The fitting will connect to a plastic tube that runs to a Yamaha water pressure gauge. The plastic tube screws into the back of the water pressure gauge.
    Easy peasy.
      use the port side plug.
      if you use the stbd side it tends to kink the line.
        Thanks again for replies that provided answer/information I needed--
