The Primer bulb leading to the Racor from the fuel tank will not stay primed. The one from the Racor to the engine will stay primed. I noticed this because when I went out in the boat today all it would do is go slow ahead. Whenever I tried to go on plane there was not enough power (rpm's would only hit 24 or 25 hundred) and it just sounded like all cylinders were not firing - it just sounded bad.
At first I could squeeze the bulb and it would eventually prime after about 20 tries, now it wont prime at all - it just stays flat.
Do I have a fuel pump problem?
