I cannot open the pictures.
however to remove the tilt piston clamp the eye end in a vise.
remove the torx screw from the piston.
don't lose the washer.
on a clean rag dump out the 5 ball/spring/rod assy's.
reclamp the eye in a vise with the piston up.
use two 5/16ths rods suck in the holes in the piston.
use a long screwdriver between the rods and rotate it and unscrew the pistion from the shaft.
to remove the free piston..
I usually do it before any further disassembly by simply tapping the up button when I remove the tilt shaft assy.
if you use compressed air to move it now be very aware that dang thing can and will fly out with force.
can be painful.
can be painful.
