1995 Yamaha 115
  • 1995 Yamaha 115
    Need Carborator float level setting. Not running correctly.
    If the carb float settings have not been changed then your poor running conditions are probably due to something else....
      I think what you really need is the carburettor float settings? These will be in your service manual, what sort of issue do you have? As mentioned, unless the float is way off, it won't cause too much drama.
