I have a 150hp yamaha on a flats boat that is cutting out at high RPM's... When running flat out it will almost quit, I can pump the fuel bulb and it will not do that. So I think it is just running out of gas. This is the first trip out this season. Any ideas?
Losses power at high RPM
seapro,
Check the diagram for your motor in the online catalog above - I think you will find that the entire fuel pump assy is just a few dollars more than the diaphrams.
A lot of owners replace their fuel pumps (I believe your motor has two) every five years just for preventive maintenance.
Ken K
