After a 60 min run my motor lost power. Full throttle only produced 10mph instead of 25mph at 80% throttle. It seemed to run smooth but I just could not get it to go any faster. I run only 87 NO ethanol gas, with seafoam added. Any ideas of where to start looking?
1985 40hp 2stroke Loss of power
what ive learned on here from the pros is when its an engine performance issue 90% of the time its fuel related, not compression or spark. Assuming your getting fuel to the carbs id check them first. Older small engine carbs are easy to remove. Dump the bowls with a white cloth, check for debris. Clean all the jets.Jason
