Flywheel Torque 1997 Yamaha 150hp
    Hopefully hub would spin first.
      RogerTammy:
      This link is for what should be your owners and service manual, thanks to Boscoe.
      https://www.yamahapubs.com/results.p...50TXRV&lang=en
      Let us know what it says in regards to flywheel torque.
      Thanks!!
      Chuck,
        Hopefully...I've sheared a few flywheel keys on my lawn mowers by hitting stumps....but the prop hub rubber liner may help a good bit...
        • #19
          Originally posted by cpostis View Post
          RogerTammy:
          Thanks!!
          Take your pick. Gotta love Yamaha data.
          • #20
            Safe side. 140 with oil. Good grief.
            • #21
              My "vote" is average the difference, dry threads..
              In real life, I'd bet many shops put an air gun on it till it stops turning, wonder what that # is?
              • #22
                Exactly.
                Just like tire shops with wheel lug nuts.
                Then the driver has to attempt to change a flat using a little joke of a wrench
                • #23
                  I had one of the diesel guys at work tighten the ball on my trailer hitch. He says"that should hold it, 750lbs with this gun...."
                  • #24
                    Yep, real life, especially when you CAN'T SEE what their doing...
                    That's why no one wrenches on ANY of my vehicles / machines (un-less it's something I can't do) and I WILL re-check torques, that the wheel WILL come off, etc..
                    • #25
                      Flywheel Torque
                      Thanks everyone for the advice. We torque it down to 140 foot pounds. Had to replace the stator too. This has been a big ordeal but your input is really helpful. Another problem is we ordered a flywheel and didn't have time to put it on before we left on vacation. We ASSUMED they had sent the correct one. Well first mistake was assuming. It was over 30 days so they would only refund half the cost of the flywheel. I said no. So know I need s spec sheet on flywheel dimensions it was supposed to be a 6G6-85550-01-00. The flywheel hole was too big. We ended up getting a 6G6-85550-00-00. It fit. So I'm not for sure what part number we originally received. Does anyone have a reference I can check?
                      Thanks,
                      Tammy
