I've got a 2000 Century 2600 CCF with twin Yamaha OX66 engines. THe battery on the Port engine will discharge if I forget to turn the Battery Switch OFF (which I did the other day -- again)
When I checked on things the Battery was showing 10.7 Volts -- I have a battery charger hooked up and it showed that the battery was in Low condition after the day or two with the switch left ON
The battery that's losing it's full charge is connected to the Auxiliary Panel and all the electronics. I checked across the 12V Lug (comes directly from the Battery Switch) and the Ground that comes directly from the Battery and my meter is showing 0.385V
What is causing this reading?
I've cleaned all the +12V posts and Ground Posts except on the battery switch itself. Century buried that switch and connected it with such short leads it's major surgery to get ad the back of that switch
Suggestions?
Suggestions?
