Hi there
Got a boat with a yamaha F115 outboard, that run okay for now all the rpm range, and changed the water pump impeller to solve the overheat at idle problem, but I found that in my gauge which didn't show the oil pressure, it just shows nothing
After a while I go to Ebay to get a PC diagnostic program and plug into my notebook to see more detail for this 2nd hand motor, and found one of thing may related, it shows in Data Logger[Data comparison graph] with engine speed
Oil press switch[0:OFF 1:ON]
all speed shows 0
But as I know that if there oil pressure problem, the motor will alarm or just can run in slow speed.
I checked about the oil and it pretty good, no "making oil" problem, no gas smell. But just see the dipstick (wipe once and pull back, then take out once again) found that the oil level over the top position.
Maybe the oil pressure was disconnected or failure? and the oil fill too much ?
This is the first 4 stroke motor to me, really enjoy for this motor fuel economy, running 3600-4000 rpm for me easy to get 5.6MPG or more.
Thanks!
all speed shows 0
Thanks!
