Originally posted by pstephens46
View Post
The fuse protects engine harness wiring and the isolator lead from the motor to the battery to which the isolator lead is connected.
And by the way, the isolator lead is protected by a fuse adjacent to the battery terminal. At least it should be. The isolator lead is hot all of the time. Powered either by the motor when the motor is running or powered by the battery if the motor is not running.
Capiche?
