Hi, I have just finished rebuilding a 1983 60C 2 cylinder 2 stroke. All adjusted by the book (carbs vacuum balanced). Seems a little lumpy at tick-over. I dont have access to a test tank or prop. I have been running it with the prop off and muffs fitted. Idle mixture screws work but dont make much difference to the tick-over lumpiness. Picks up fine and runs well at other speeds. Many new parts fitted including CDI, carbs fully rebuilt and adjusted. Compression 143 and 145psi.
Any ideas on fine tuning ?
Or is this just normal ?
Thanks Neil
Thanks Neil
