Will this work as a parts motor for a 2010 F25? 2006 has a busted handle and pivot bracket. Also clamps for transom are broken. Don't know if it will run as has been setting for 3 plus years.
2006 f25
2006 and up is in the same "build range", ie, for picking parts, Yamaha shows 2006 and up. That doesn't mean there hasn't been any changes, so be aware, a yamaha is not a yamaha..
2006 and Later 25MSH Yamaha Outboard Parts
You didn't post a specific model but you may want to check specific part numbers against each year/model #
Someone else should chime in but the above will get you started..
Good luckScott
