Rodbolt, his 3 breakers are all wired together with a hot wire going off to the battery and a ground wire going off to the battery.
For his accessories he was to fuse, there is ONLY ONE TERMINAL for each breaker(positive I'm assuming and no negative terminal to attach. (likely to ground those accessories to the battery directly..
I think this is it:
http://www.ebay.com/itm/371695199668...466&rmvSB=true
I think this is it:
