I've tried numerous pullers and can not get flywheel to budge. Its like I'm missing removing a bolt or something. Any help please. Need to check pulsar coil....
2004 vz260tlrc hpdi flywheel
If the shift position switch is faulty it tells ecu neutral and kills cylinders #2 and #3. Shift cutoff will kill 4 of 6 cyclinders. Neither issue is what I have. I have cyclinders 1, 3 and 5 randomly firing. It makes no sense. I've checked pulsar coil with multimeter checks good but my problem comes and goes... I don't know what else is in system. YDIS shows this happening but says evert hinges is good and doesn't throw codes. That's why I wanted to look at coil for corrosion and may just replace it to see what happens
but at the same time your telling us you suspect a pulser coil(6 of them) has failed 3 coils at the same time?
the only other thing that will affect a complete bank is the charge coil.
that motor uses two charge coils that control each bank lose 1 charge coil lose a bank.
charge coil is part of the stator I think, as I do not see it listed separately.
If you look in the service manual you will find specs for it and the leads to test
http://www.boats.net/parts/search/Ya...TOR/parts.htmlLast edited by 99yam40; 08-02-2016, 10:19 AM.
