Can I run my motor without the thermostats, will it harm anything
115hp 2 stroke thermostates
Originally posted by piper8150 View PostCan I run my motor without the thermostats yes, will it harm anything possibly
You can run without the motor cover. You can run without the trim and tilt system being installed. You can run without the intake box being installed. You can do a lot of stuff. But why?
because there out for testing and they are good ,I guess I just want to know why I need them. If they stick shut you overheat. why take a chance if it does not hurt anything ? or maybe it does ?
Originally posted by piper8150 View Postbecause there out for testing and they are good ,I guess I just want to know why I need them. If they stick shut you overheat. why take a chance if it does not hurt anything ? or maybe it does ?
if you remove the stats on any water cooled motor, there will be areas that run too cold and other areas that run too hot due to the water not circulating as it as designed to.
Some recommended to put a restrictor in place of the stats to force water to all of the places, but why do it. just keep proper working stats in them as they were designed.
+1 ^^^. They do help regulate the water flow thru out the engine..
They also help the engine warm up to normal operating temperatures as well.
If your flushing regularly and inspect occasionally, their pretty much maintenance free...Scott
ÂÂÂÂÂÂ
