I have a 1998 S200TXRW. Engine starts and runs great, then when I come of plane and need to throttle back up the timing seems to be off. If I push too much throttle the engine will die but would start right up. So I just put the throttle in gear, as if i was going thru a no wake zone. After a minute or so at this speed I'll slowly add throttle and if it bogs down again I'll pull back on throttle and just putt-putt along. Eventually slowly adding throttle the engine timing begins to catch up then it runs great with no issues until I come off plane again and have to go thru the same procedure. The longer I run up on a plane directly relates to how long I will have to putt-putt along until engine will allow me to jump back on a plane. Long run (30 min.) may take 15 minutes, short run maybe 1 or 2 minutes....for a car analogy it's like someone was turning the distributor while timing a car, slowly getting bad to good.
Replaced the fuel pumps and throttle roller which did not help. WOT timing and idle timing are correct.
Thanks for any insight you may have.
