as I said before, try blowing compressed air up the TT while running to see if that will move things around so a solid stream can be reached again.
Small bits of scale flaking off of cooling passages or sediment picked up when running in shallow water can get in the way and cause tt to spray on my C40 from time to time.
usually running some weed wacker line up it while flowing water takes care of the problem.
I guess if that is all clear then maybe you are getting exhaust into the water stream.
