I have been led in this direction to seek out a particular member that has re jeted this specific motor with good results. I have cleaned carbs repeatedly, run treated fuel, synced carbs and the motor still seems to be running lean. I believe the pilot jet is the problem but mid range is also acting up.
Runs a little better after cleaning but goes down hill fast. It may have run ok from the factory but it seems that any build up (ethanol residue) on the jets will make this motor run poorly. I don't use this motorboat very much which I know is one of the problems but when I do use it I need it to run correctly!
Knowledge is power, please enlighten me.
