Problem:
Gasoline(? or water) getting into the oil in the sump.
Engine: 2005 F90 LTRD 4-cyl. Very low hours on it.
History:
Noticed about 8 oz of extra fluid in the oil. Smelled like gasoline. Drained the sump. Dismantled the fuel pump and inspected the diaphragm but found no defect. Replaced the fuel pump with a new one anyhow. Had the fuel injectors cleaned (but not pressure tested). Put new oil in the sump.
Ran the boat for about 3 hours. Found about 6oz of extra fluid in the sump. Smelled like gasoline but the milky appearance looked like water. Engine ran fine and plugs are clean and appear to indicate clean ignition. Drained the oil and let it settle in a glass container for 48 hours. Upper 6/7ths of sample looked like clean oil; bottom 1/7th was light grey. Grey fluid at the bottom doesn't look water.
Is there any other way that gasoline can get into the oil other than through a defective fuel pump or bad injector? Or is this water, which might indicate a blown head gasket or ???.
Thanks,
John
History:
Thanks,
John
