I have spent a few weeks surfing this site and this motor has got the best of me. so finally decided to join for more help. Start off with thanks for all the help this site has given myself over the past few years.
Ok now my issue I just obtained a new toy 26 ft offshore boat that has sit for "9-10" years. salt water ran. She came with twin 200 yams 200txrp and a 200txrq the p is my problem child. Took boat for test run before buying and motors started right up cold and ran strong. Brought her home and we have alarms and issues. Started off with all 3 indicators blinking on the yamaha tach. So did a diagnosis and the aux oil pump was shot along with the trim tab sensor. swapped them out and oil alarm vanished. We took her out and filled the fuel tank up about a mile later same motor shutdown and won't start. Found a cracked fuel line under deck removed and replaced and then started carb problems and lack of fuel. Did a at dock carb spray down clean and got her running ok. Brought her home after a week took out for a test run and motor wouldn't fire finally got her running with a fouled plug and a bad fuel pump an over heating alarm and the tac wouldn't read the rpms. Since this happened a week ago I have removed cylinder head cover and exhaust outer cover cleaned the salt residue and reinstalled. checked pressure valve and seems to be fine. Have replaced thermostats along with impeller. Still having an overheating alarm and motor shutdown with just the red indicator lighting on the gauge.
So the 200txrp has new impeller, thermostats, aux oil pump, spark plugs, both fuel pumps, fuel lines, exhaust and cylinders cleaned of salt residue, trim tab sensor. My issue is over heat alarm constant even at start up got motor up to 4000 rpm and shut down. alarm is constant tack reading will work 50% of the time and only the over heat marker is lite up. Also tried unplugging both thermo sensors and alarm still sounds. any help will be grateful
