I have a 1987 Yamaha 80HP outboard 2 cycle motor. The engine has 3 carburetors. When the engine is tilted up, fuel leaks out of the bottom carburetor. The top 2 carburetors are just fine. Since I leave the boat in the water several weeks at a time, I want the engine tilted. The fuel drips out of the engine cover and on to the stern, then, goes into the canal. Essentially there is a fuel slick around my boat.
One solution I have read is to disconnect the fuel line and run the engine out of fuel before tilting. I can do this but I have also read that this is not good for the engine. Don't know why.
Since only the bottom carburetor is leaking fuel when tilted, I am wondering if I should remove and clean only the bottom carburetor. Maybe rebuild.
Any thoughts would be appreciated.
